Teamsprock »
https://forums.nicoclub.com/teamsprock-u20550.html
Mon Jul 11, 2005 12:08 pm
Are the threads stripped on the hard line or in the block! If its just the lines buy some Taka lines and call it good! You can find those most anywhere(Heavythrottle, Phase 2, Enjuku) If its the block side then I would helicoil it! Another thing I guess you could try is some Copper RTV if its not stripped too bad! I'd try that before the silicone but either might work.
