Alpine w505
bbynssn
Car: 2008 Nissan Altima 2.5S Sedan
I had this double din in my tC now I wanna put it in my Altima, any suggestions on dash kits for this?? Thanks!
headhunt3r
Car: Altima Coupe 2.5S w/ CVT
AppleBonker wrote:Installation
4th Gen
Always make sure to disconnect the positive terminal of the battery before doing any installation work. This is imperative to protect your system and, more importantly, yourself from electrical shock. See this article for pictures and step-by-step installation instructions. Thanks to Doc for this one.
If you have manual climate controls (there is no digital LCD readout on these), grab this kit for installing either a single DIN or double DIN radio. It will keep the factory look around the radio.
If you have automatic climate controls (with the digital temperature readout), there is not a factory piece that can be used. You can buy the navigation panel, but it will have a gap. The metra kit mentioned in the install article above should be used to avoid the gap. Or, you can fabricate your own panel (but this is not for the beginner).
- from the FAQ. Go there for links!
bbynssn
Thank you so much!
