Alright Will Be ordering pending positive reviews.
Fronts and Rear:
Alpine - Type-S 6-1/2" 2-Way Coaxial Car Speakers with Poly-Mica Cones (Pair)*Handles up to 240W peak power (80W RMS)*6-1/2" poly-mica woofer cones with high-grade strontium magnets and Santoprene surrounds deliver rich, deep bass; stamped steel frame for high rigidity and minimal resonance *Impedance: 4 ohms
http://www.bestbuy.com/site/ol...etail
Next The Sub:
Alpine - R-10" Dual-Voice-Coil 4-Ohm Subwoofer*Handles up to 1500W peak power (500W RMS)*KEVLAR-reinforced pulp cone, oversized parabolic dustcap; HAMR surround and concealed mount gasket (KEVLAR is a registered trademark of DuPont)*Impedance: 4 ohms
http://www.bestbuy.com/site/ol...80920
Alright, to power the 4 corners,
Infinity - 468W Class AB Bridgeable 4-Channel MOSFET Amplifier*Continuous Watts per Channel (4 Ohms) 75 x 4*Continuous Watts per Channel (2 Ohms) 90 x 4*Continuous Watts Bridged 180 x 2*Max Power Watts per Channel (2 Ohms) 117
And Finally to power the Sub,
Alpine - 500W Class D Mono MOSFET Amplifier with Adjustable Crossover*500W RMS (continuous) power x 1 @ 2 ohms, 14.4V, 20Hz - 20kHz, <1% THD*300W RMS (continuous) power x 1 @ 4 ohms, 14.4V, 20Hz - 20kHz, <1% THD*MOSFET power supply delivers clean power with minimal heat dispersion; thermal management control helps prevent overheating
http://www.bestbuy.com/site/ol...10874
I understand the kind of power this system can put out, matched with a deck. As for your opinion, would this be a nice combination of components?
all additional specs of components may be found on the link provided below each product, posted only a handful for sake of readability.
