tagbok »
https://forums.nicoclub.com/tagbok-u24881.html
Fri Jan 21, 2005 12:36 pm
This is for all those guys out there who've done the de swap into and 89 or 90. (mine is and 89)
What i have:
#95 ob2 ka24de (probably a 96 engine sold in a late 95 (know its obd 2 engine cause of the colored ecu plug, blue)#96 mafs#ingen intake (for the de) got this when i found out the stupid 96 mafs wouldnt fit into the stock 89 air box#Both harness's (the wireing is done)#Corresponding ecu (from a 96 mt)#89 manual transmission#new alternator (95+with foglights dont remember exact specs)#starter from the e (was told theyre interchangable)#new belts (alternator and drive belt, keep in mind the drive belt runs crank, water pump AND power steering. heard you can get a belt to run just the crank and water-pump but i know nothing in detail on the matter#the e powersteering pump#new battery(i am using both the exhaust manifold and intake manifold from the ka24de that is being swaped in).
Ok now for what i know i need still to get#new water pump#new fuel pump#95+powersteering lines and resivior#tach from 91-93
This is where i sit on my swap as you can see its been 3 long months (full time work & full time student). not much time for play
Now for the questions#Ive heard that using the exhaust manifold from a 91-93 is a smarter idea anyone done or heard this?#The lower radiator hose from a sr20 is said to have a temp sensor in it; that would be cool anyone know any truth to that, if so through minor manipulation think it would be made to fit the de?#When i bought the car, the swap was in progress, ive done my best to turn the progress from a disaster to working order, but ive no idea which throttle cable is currently in the car, anyone know if there is a way to tell?
If there are any suggestions that anyone has, or ideas helpful hints im all game. Ive read a few swap guides alot more posts and consulted a few shops, as far as i can tell im covering everything before i throw this thing the rest of the way together but if ive left something out would be GREAT to know
