Just another 240 »
https://forums.nicoclub.com/just-another-240-u643.html
Mon Aug 19, 2002 4:20 pm
On the recently past saturday morning my engine shut off on me twice during a turn going to my friend's house, i can't come up wif a conclusion of why it is doing that so i was like **** it because we have to get to work. After work when i was going bak home i notice that when i HOLD my clutch during 3rd or 4th gear my rpm drops lower than idle speed (holding as in just press and hold without changing gears or ne thing.) So i was testing it to see if that is how my engine was shutting off on me in the morning. While doing that on the freakin highway doing like 50mph-(it was raining and the road was wet )it actually did shut off on me again cause my rpm drops down to 400 and shut off. During that morning i was thinking about it and was scared that it mite happen to me on the highway(which it did) so i asked my friend in advance how to kick start or push start a car, i did what he told me. I putted in 2nd gear and pop my clutch, the torque was so great that my rear end spin out did a almost 180 degree turn , landed from the middle lane to the right lane and almost hitting the wall, now that i'm facing the other way of the high way-i can't get bak to the flow of the traffic. Luckly no car hit me and a garbage truck saw me, helped me block off 2 lane and let me get bak on the correct way of the highway.That night i called my friend and told him what happened and he told me that i wasn't suppose to be on 2nd gear to push start it casue i'm already going like 50mph, i'm suppose to put it on 4th or something.I have a 1 vacuum leak and recently i've just put in my air cone filter so i left the hose from the lil box(i think ppl call it the resenator box?) hanging-that makes 2 vacuum leak, i think those vacuum leaks are making my rpm dropping so low. Would that be the cause???
