x3rikaa »
https://forums.nicoclub.com/x3rikaa-u132518.html
Sat May 09, 2009 7:09 pm
okayyy so my car is almost up to spec :] except now i have a transmission problem :/ maybe some of you can point me in the right direction:
sometimes, when i put the car into 1st still with the clutch down, i hear a LOUD noise, as im letting off the clutch and giving it some gas. its not necissarily a "grinding" noise but it is a disturbing/uncomfortable one. my research found that it could be a TOB or pilot bearing but nobody seemed to have experienced the same noise as i have. i would youtube it but this only happens once in a while...(ive probly driven it for 6 different days and it has happened at least once for 3 out of the 6 days)
and thenn with my car off, when i push the clutch down slowly ill hear a slight feint "squishing" sound. i have bled the clutch already and the fluids are nice and clear. the master cylinder and slave look brand new. anybody have an idea or can tell me where else to check?
aand while driving and changing gears, my clutch only comes up about 90% of the way. i have to pull it up with my foot the other 10%. is that how its supposed to be? it makes me feel uncomfortable cuz i dont want it to be as if im "riding the clutch" if i dont manually pull it up.
OH one more thing, im having a hard time going from 1st to 2nd. while i change gears i SOMETIMES also hear a weird "rrrrrrrr" sound. (that might not be the exact noise tho lol) could that be the flywheel? this happens when i go from 2nd to 3rd too but 4th and 5th gear is fine :] i have already changed the fluids with redline shockproof heavy (previous color looked like green vomit) and according to the previous owner, there is a new clutch inside. any suggestions?
keep in mind that the car has been sitting for almost 2 years :/ (last maintenance and last time parts were installed). could/do any of these components deteriate over time withought being driven? like does the clutch disintegrate over time just sitting in fluid? lol (i dont even know if it sits in fluid so dont flame)
so if anyone could give me ideas or suggestions or things to check that i may have overlooked, let me knoww! IM ALMOST THERE, NICO! DONT FAIL ME NOW!! :]
*oh yeah, it has been 5 speed converted if that makes a difference. so with that being said, maybe the whole clutch pedal might not be bolted on good? causing the 90%/10% problem? ill check tomorrow but just thought id add...
Modified by x3rikaa at 10:42 PM 5/9/2009
