almost stalling
onevia90
Car: nissans, games, movies, latinas
hey whats up i have an s13 with a sr swap stock turbo, s15 injectors, r33 fuel pump, greddy intake manifold, apexi exhaust, blow off, hks intake and fmic, blitz sbc-id runnin 12 lbs of boost.I dont get on it much but when i do after i let of the throttle and put the clutch in the rpms drop fast, slows down around 1k then it drops down to like 300 and almost stalls and a few times it has so if anyone has had this problem or knows what it is or has any suggestions please let me know thanks
i think its the blow off but im not sure about the whole recirculating thing
man2199
You may be running rich.If your BOV is not routed back to the intake it will cause the car to go rich when you let off the gas.Causing it to want to stall and other drivability problems.
s40sxDragon
Car: umm, could cars be it???
Sounds like a few probs, but man said it pretty much, just takes some minor tweaking.
