dsylvia »
https://forums.nicoclub.com/dsylvia-u25005.html
Sat Sep 10, 2005 10:21 am
all runs performed with 93 octane gas.
started out with a simple run at 9lbs of boost. the numbers were like 250hp, maybe lower. i cant remember exactly. i had never been on a dyno before, so i didnt go full throttle and didnt rev it out.
as the runs went on i got used to being on the dyno and we upped the boost in small increments. after letting the car cool down and upping the fuel pressure a tiny bit to be on the safe side, I cranked the boost to 20psi and this is what i made... keep in mind, that run was the last one. i had been on the dyno for an hour. so if i was to run that psi for my first run next time, i would prolly net numbers a bit higher. all in all, im happy. not 400hp, like i wanted, but damn fukkin close. I'll have more pictures and stuff later on.
set up is as follows.....turbonetics t3/t4 ball bearing, 50 trim, .63 A/R, stage 3 wheelturbonetics deltagate wastegateETD manifoldgreddy front mount intercoolerbuilt engine:pauter rods, supertech pistons(8.r C/R, .020 over)ferrea valve springs and retainersport and polish, 3 angle valve jobcometic head gasket
