GirlRacerS14 wrote:Wasn't a low blow. Just giving you an example of what I had with good reactions on fewer mods. You'll have much better times once you get that reaction all worked out. I worked very hard on my reaction times. You'll get there. Just keep at it.
GR
Reaction time has nothing to do with the overall time. The reaction time is the time between then the light turns green ant the moment you leave the staging beams. The actual 1/4 mile time starts when yur car actually leaves the staging beam. sO in other words, you can let the light turn green and sit there. the clock won't start. Your reaction time will suck, but the 1/4 mile time will start as soon as the car gets going.
As far as 0.468 being a bad time, it depends. Some tracks set a perfect reaction time as 0.000 and some at 0.500. 0.468 on a 0.500 tree is pretty good. In eliminations, you would lose since you broke out, but it's close to 0.500. And if you don't break out slightly every once in a while, you're not trying to get a perfect reaction time.
Generally, you want to start to move about when the last yellow light turns on. By the time you drop the clutch and you car gets through the beams, the green light should be coming on.
