almost feels like turbo lag on an N/A....
S13ean
Car: 91 240sx SE coupe, 04 6mt coupe
alright, whenever i do normal driving in my s13 and i start off from a stop, or right after i shift, i get what seems to feel like throttle lag. it doesnt do it all the time but when it does, its noticeable. it does it mostly when i shift below 3k. ive done alotta matinance on it(maf, water pump, belts, full tune-up, batt, etc). it doesnt seem to do it whenver i get on it too. but it usually lasts about 1 full second, then surges forward. im gonna clean up my maf, but past that im stumped.... thanks for your help!
masticatingcow
Car: 94 Mazda FD3S
Could it be your driving style? If you dump the clutch with sticky tires you'll get bogged down low in the RPMs. Nature of the beast, unforunately. Work on feathering the clutch, if you can. Once you get the wheels rolling, they'll provide a LOT less friction against the transmission and crank.
mr_wizard
Does it do it when you first start the car? I know I had sorta the same problem on my first 240. I went through 6 mechanics and took me 2 years but I found out it was the spark plug wires. When the motor was cold it was fine, but after it warmed up I couldn't give it much gas without it sort of sputtering. Also, it could be your TPS. There's a write-up in the KA24DE Article section of the forums on the testing procedure.
S13ean
masticatingcow wrote:Could it be your driving style? If you dump the clutch with sticky tires you'll get bogged down low in the RPMs.
the driveline is stock, and my tires are directional, but nothin special and sitcky. plus i have stock suspension .
mr_wizard wrote:Does it do it when you first start the car? I know I had sorta the same problem on my first 240. I went through 6 mechanics and took me 2 years but I found out it was the spark plug wires. When the motor was cold it was fine, but after it warmed up I couldn't give it much gas without it sort of sputtering. Also, it could be your TPS. There's a write-up in the KA24DE Article section of the forums on the testing procedure.
it happens alot more when its cold, but still does it here and there when its warmed up. my wires/plugs are only couple months old. when i go from a start it sputters and lags until like 1500-2(when it happens, that is). i dont think my tps has ever been touched, so ill look into that. thanks
KADreams
Car: 1991 Nissan 240sx Fastback SE
You could also be feeling the throttle tip-in timing retard of the stock ECU.
[email protected]
im going through the same thing. its probably your crank angle sensor. you have power surges from like 1000rpm to 4000rpm right? and sometimes your idle stumbles? check your ecu for codes. cas = code 11. you need a new distributer if that is the problem.
S13ean
[email protected] wrote:im going through the same thing. its probably your crank angle sensor. you have power surges from like 1000rpm to 4000rpm right? and sometimes your idle stumbles? check your ecu for codes. cas = code 11. you need a new distributer if that is the problem.
i forgot to mention, i just recently put on a reman dizzy
Dammitboy
Car: 92' Nissan 240
KADreams wrote:You could also be feeling the throttle tip-in timing retard of the stock ECU.
This is more then likely what you are feeling. I had it also untill I tuned it out with a daughterboard.
rectifryer
Car: 240sx
this is a classic clogged cat issue it sounds likeyou can check to see if its hotter than the rest of the exhaust ten minutes after your car is turned off...you guys prolly know more about it than me honestly
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
yeah same damn things happenin to me..i gots da 89 240 wit the sohc 5 speed.. it shift at like 3 grand it bogs a lil then picks right up.. pisses me off.. ..i was thinkin the choke mite be stickin too ebcause the firsst like half hour of me drivin it..likw 10-20 mintes into it..im coastin wit the clutch ina nd with it in neautral both way...the thing idles at 1500 and then slowly goes up to 2K and then drops back off to 1500 really quick then goes back and does it for like 5 minutes...unless i drag the clutch in first gear when its parked but the power in not effected when i put it back ion 5th gear after i coast..idk what it could be..thanks alot
garrett h , NY!
