BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Wed Nov 12, 2003 6:27 pm
I've almost got the swap completed but I have a few questions on small things that are hanging me up. The main question I have is how does the harness route? The place that did my harness extended everything and made it so the ignitor will mount in the stock location but I'm having trouble getting the harness routed neatly. If anyone has a picture or diagram of how the harness should route I'd really appreciate it.
The second thing is the stock rubber intake tube, It has 2 extra ports on it and one vaccume connector and I can't seem to get it on the turbo and fitting nicely. Anyone have an idea or picture of how it should be position and what the ports are on it. I know one is for the BOV, but I have no idea about the vaccume port or the other port on it.
I also have a Greddy Hotpipe but it doesn't quite seem to be long enough to reach my lower intercooler pipe (Hybrid FMIC), am I supposed to have to enlarge the stock hole or what?
The last problem I think I've solved, but my throttle cable wouldn't work with the stock cable mount on the intake manifold, it was keeping the throttle plate open all the time. I had to cut the stock KA cable mount in half and grind it a bit to get it to hold the cable where it needed to be.
Any help would be great and pictures would be even better, I'm trying to get it running by this weekend if I can.
