Globalsilence »
https://forums.nicoclub.com/globalsilence-u34552.html
Wed Jan 11, 2006 9:54 pm
I have an 95 240 with 90,000 MI. I rebuilt the motor with forged internals and am at the final stages. I have a walbro 255 fuel pump, deatschwerks 700 CC injectors, t3/t4 50 trim .63 AR and an Enthalpy tuned ECU. So for the past 2 weeks i have been trying to figure out why the car wont fire. It has air, fuel and spark. When i crank the car it sounds like it wants to start, but immediately the spark plugs get soaked in fuel. I just replaced the distributor rotor and got new plug wires. Checked the spark and it's fine. The distributor is in correctly, i have double checked it against the FSM and online write ups. I think the ECU was tuned wrong. If the ECU was tuned for 500CC injectors and the car actually has 700's would this explain why the car wont fire. Is there anything else i need to check? Maybe the stock FPR is bad? I don't think the injectors are leaking because all the plugs are soaked not just one or two which means either none of them leak, or all of them leak.
The MAFS is wired correctly; I checked it against what everyone said and all the diagrams. C is running to the chassis and D is going to the stock KA ground wire. I really don't know what else; I guess I’m just hoping that it’s the tune that’s wrong...
