Agreed...I've got a little bit lighter clutch than Bart is running (stage 2 TZ) but it rocks so far. Can't wait to really try it out. The clutches are VERY reasonably priced too...got mine from Jason @ z31parts.com and he was very helpful.mtcookson wrote:Oh yeah... and DXD Clutches FTW! Those are the guys I'm going with for a clutch next. They make some awesome clutches and have incredible customer service from what I've seen so far.
Yeah i hope it turns out to be a good clutch mines a DXD-FX Series Stage 6 for a 350 ZX, my fly wheel has been modified to suit.tmorgan4 wrote:
Yep, you should get it balanced anyway, but yeah, when you get it re-drilled definitely, but then you can buy the fly wheel allready re-drilled ready to go from Southbend clutch.With the 350Z pressure plate it has the advantage of a lighter feel on your foot, not only extra clamping force (apparently) as i havnt used it yet.tmorgan4 wrote:I was going to ask you about that...I was about to go with the upgraded pressure plate like you got, but the flywheel had to be re-drilled and I just didn't need the extra holding power for my application. Did you get the flywheel re-balanced after having it re-drilled?
If you don't mind saying, how much was that adaptor plate? I don't know if Wes's plate will ever get madeBart wrote:No its not a Dixon, i bought it from Perth Australia. company called AGI
Modified by Bart at 4:37 AM 4/9/2008
ExaclyChrispy300 wrote:From what I understand you are trying to have a longer spigot bearing because you are using a spacer adaptor for the gearbox. Because of this spacer the input shaft for the gearbox will be too short to fit into the crank. Is that what you are trying to do with the stepped bearing?
whats ur email ill email Derks numberBart wrote:The plate was $370 delivered approx. The blokes name is Derk, ill pm his number.Mettler in your opinion will this setup be ok?
Actually come to think of it, it wouldnt matter too much if the bearing was further into the crank, if i remember correclty their is a shoulder inside the crank which is approx 10mm deep, after the shoulder it opens to a larger diameter so a longer bush would be useless as it wouldn have anything to hold onto??Bart wrote:half is in the crank, 10mm in the crank, half is kind of in the breeze but the gearbox shaft is in the bearing.
