book-ends »
https://forums.nicoclub.com/book-ends-u3879.html
Fri Aug 29, 2003 10:31 pm
Hello,
If you have to hold your wheel a little off center, then it might just need a quick alignment (like my car currently does)............if you have to hold it a lot off center, then you might have ruined either your tie rod end or stripped a few threads on the tie rod. That sounds pretty extreme though but it's always best to go with the worst case scenario as you'll always be pleasantly surprised when it's something less diabolical.
As an aside, I suppose the worst thing that could have happened would be that you actually BENT the lower portion of your front upright.
