Allignment angles for lowered G
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Thurgood22
Car: 04 G35 Sedan Sport 6MT
I am planning to lower my G Sedan but i dont know what camber angles to adjust the wheels to. Its my everyday driver and i dont want to sacrifice my tread-wear. Any suggestions??
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Welcome to NICO!!!
You might look in the FAQ at the top of the G35 forum, then search the FSM (factory service manual). I'll bet your answer is in there. Off the top of my head, I don't know that correct answer.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
You have the Sedan, meaning...if you were to put the coupe suspension on you would lower .5", 350z suspension will lower you 1". Beyond that you will be out of factory adjustability and will need aftermarket parts (camber kits, upper A arms, etc ) to make adjustments without sacrificing treadwear. Also dependent upon how much you lower of course.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
-.5 to -1 degree would be my suggestion based on my last car (I30).
I love seeing these little hondas with -3 or more degrees. I can't wait to see their front tires shred and have them put on the stock rims
Beancooker
Sentientbydesign wrote:-.5 to -1 degree would be my suggestion based on my last car (I30).
You know that the G has negative camber on the back wheels stock, correct? I believe it is -3 stock... Our tires don't shred...
Sentientbydesign
96 I30 - Sold
I'm pretty sure it has negative camber on all 4 wheels, but negative 3 degrees is unlikely. I'll go look
Sentientbydesign
96 I30 - Sold
Per the 05 coupe FSM
Rear Suspension
Camber
Front
Min:-1.25 degreesMax: -.5 degrees
Min: -1.75 degreesMax: -.75 degrees
I'm not sure if that takes into consideration the Sports Suspension
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
