all you 240 mechanickz need some help
tricktunes240
Car: 1992 240sx fastback
i just took my car 92 ka24de to a show had them look at my "sound" which is a timing problem...they wanted $1,800 to fix it for me ...haha ill get a sr b4 i do that..anyway...at idol it makes a clicking/rattling sound but when i rev it up just a bit and hold it...sounds perfect...what could it be that would help me from getting a whole timing kit...possibly guides? or maybe just chain? thanx for input...
mattscar
Car: 1989 240sx, 1992 Miata
i not a mechanic but your prob sounds familiar to our corolla and we changed the vaccum lines and it was better.i dont know just see if its fine i guess?
rsmithdrift
Car: 1993 240sx fastback se.
Sounds like timing chain guides to me. Remove them.
Toshima
Car: 93 240sx, 93 sc300(m/t)
Its a common noise with the ka dont worry about it. Ask around and alot of people will tell you that there ka make that same noise all the time. I believe its the guides.
byonata
Car: '89 KA24E
Mines does the same until i forgot to put oil and blew it all up. It sounds like timing chain. I should have a picture inside the valve cover.
This is off an 89' 240sx KA24E single overhead cam SOHCTOP VIEWFRONT VIEW
tricktunes240
would it be safe to remove them? or will it cause more problems...
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Remove the guides, search under the FAQ's or tutorials for a details and pictures. If you still have rattling, yes you are going to need a timing kit. Very expensive unless you do it yourself. And if you wait until later you will be looking a major damage and more $$$$ when the chain cuts thru your engine cover or valves hit the pistons...oh remember you have a DE, the pics on the thread show a SOHC...
180fan
Car: 89 fastback
The DOHC's, you can remove the upper chain guides without issue. Both the DE and E, you MUST keep the lower guides. If you've got an E and hearing a rattling sound, it could be your lifters.
jrb92se
Car: 1989 Nissan S13 coupe
try marvel mystery oil half a quart
tricktunes240
marvel mystery oil eh? sounds intense....i jsut took off the top guides in under 15 minuts and assembled everything started her....still go the sound...so i figure its the top side...o well.......if its not hurting anything i guess ill just deal with the sound and as long as i can still beat a BMW z3 with the sound(like i did last night) itll be ok....by the way its a DE..thanx for input guys
sxcoupe
Car: '95 bmw M3 coupe
that cliking sound is your timeing chain guids cheak out this link
sxcoupe
remove them and problem solved. cheak out the link
fullthrtl_tech
Car: 93 240sx
yeah the sound is your guides, the noise goes away somewhat because your chain has hydraulic tensioners and as you increase rpm oil pressure goes up. Yeah i am actually doing mine right now, kind of a pain in the *** but pretty simple compared to some. I picked my kit up for a dohc from a guy called the parts dinosaur on ebay for 155 shipped and thats both chains, guides and tensoners.
