All rb coil pack problems solved never have a problem again pics
turbocrisper
Car: 89 Nissan 240SX hatch RB20DET
These are some pics of my rb 20's new coil setup i removed the the factory igniter and original coil packs and relaced with GS400 ones that have built in igniters http://www.cardomain.com/membe...l.jpgI have yet to see these ones fail after five years of working for lexusany question or parts info i would be glad to answer the price the coils Is 382$ for the set brand new
eh?
Do you know if the RB20 ignitor dwell time is the same as the GS?
turbocrisper
i do not know but i thought that was set by the ecm the igniter is just a lowly transister i thought my car runs the same and the gtech said the same hp
eh?
It's important because over time you can fry the ecu ignition drivers and/or the coils. Who knows maybe the GS coils are good match with the stock dwell length.
turbocrisper
i will check the dwell with my dvom today and report
Shahee1
Car: 1993 240sx w RB20DET
OK ... You have to send a wiring diagram and more pics ... I'm really interested in your setup. Mainly cause I chaned my setup to Buick Grand National coils but I have an extra motor and this setup would probably be a much more robust and reliable setup.
Carl H
the ecu does control dwell angle, ive got the exact addresses mapped out in the ecu for romedit...the real trick here is if the coils are the same impedence as the stockers, but i dont see why you would want to go with coils that have integrated ignitors.personaly i like the coil + ignitor bit as there is enough heat generated by the coils that adding an ignitor on top seems like its asking for trouble.for the price of the coils you posted you can get a set of splitfire coils, but interesting idea none the less.
turbocrisper
i have never seen them fail in five years and the the heat is ffurther away due to the top of the valve cover mountingas for impedence the toyotas have more by quite a bit 5-6ohms
takaramotors
Car: Nissan Skyline PCG10 GTR
we carry the factory replacement coils for 375 shipped for all 6 just email us [email protected]
