Thanks for the info. Man too bad i live in california, i can find 91PhopsonNY wrote:Mines ECUs are typically tuned to 100 octane in Japan which equates to 96 octane approx. in US.
http://hondaswap.com/reference...59435/
However, I was suggesting you try it and see if you gain any benefits from it also. Too expensive to do always with a daily driver.
have fun
Explain how adding fuel is the same as race gas. In reality its far from it. Adding fuel just makes the car run richer with no good effects whatsoever. Race gas (100+ octane) is used for the higher level of detonation resistance. Which allows increased timing, closer to 12.5 AFR tuning, and alot more boost. You can use Water Injection as a replacement to Race Gas but your limited to whats in the Water Resovior. Its way cheaper though.S13240 wrote:Just get an afc and add more fuel is the cheapest route I'd go instead of buying almost $10/gal gas.
yeah, but I guess it isnt as convient as goin to a pump.180fan wrote:David, you're not looking hard enough. You can find 100 octane down in San Jose or you can buy 76 cool blue by the drum at Mach III.
No worries, we're all here to learn. I thought I've learned it all wrong after all these yrsDrifterProdigy85 wrote:my bad. i took it a different way. sorry.
