im two techno wrote:I want to buy a 84 Z22 block and remove the crank out of it and rods and have it custom fitted to a KA24DE block and have the block decked. This would give me a KA22DE with a 90 mil bore and a 92 mil stroke. With the DOHC head good valve train I’m sure it would rev real high! I talked to a machinists and he told me he would have to cut off the fronts of the cranks and swap them and re mill the crank journals to make a lower stroke KA block. I would like to try this as a prototype in NA form with 11.1 pistons and revving to 8 k I wonder where it would peek out too? An Sr is 86 mill 86 bore this motor would be 90 mil 92 stroke
HUMMMMMMMMMMMMMMMMMM
im two techno wrote:Thanks devious I’m sure I will have allot of questions. I have a friend who is a machinist and is an expert on ford block building crank balancing the whole deal. This KA22DE motor has never been built and I plan to do it all motor just to see the out come of a hi reaving KA motor that’s all most square but larger than a SR I think the out come will be surprising and I’m looking forward to an 85k rev limit. If I can work this out NA the next one I build will the for turbo bottom mount and ill be looking for 600HP
PS I found a Z22 block for 150 bucks with a good ole forged crank!And im going to use th cheapest parts a can findAnd my friend is about to give me his KA24DE engine so its time to play:ylsuper
