all motor power
ratm
Does anyone know the maximum amount of power the ka24de can produce NA?
Zebrahead
Car: cars, basketball, girls, fishing
My best quess would be a little over 200rwhp. That would be like I/H/E, cams, clutch, ECU, compression increased, flywheel, pulleys, port/polish, etc.
I think you could hit mid-low 14s pretty realistically with over 200rwhp w/ a 2,800lb RWD car.
Nick
Daunttless
The "most" power is 300, but that is a VERY extreme not suited to street use setup.
200 is reasonable with a lot of work.
sheadee240
What's I/H/E mean?
Zebrahead wrote:My best quess would be a little over 200rwhp. That would be like I/H/E, cams, clutch, ECU, compression increased, flywheel, pulleys, port/polish, etc.
Nick
Daunttless
Intake/Header/Exhaust, standard bolt on N/A mods.
ratm
would you be able to make over 300 hp with a complete engine rebuild?
TrunkMonkey
Car: 2000 Lincoln Navigator
ratm wrote:would you be able to make over 300 hp with a complete engine rebuild?
you can, but not if you rebuild it back to stock specs. you'll need lighter internals, raised compression, headwork, wild cams, any and all bolts ons you can get. if you decide to stick with EFI it would probably be best to ditch the ecu and get a programmable stand alone unit. switching to carbs is an option too.
but like dauntless said, it probably wouldn't be streetable.
Daunttless
Heh, it wouldn't be streetable unless you're Takumi. : )
technoman
Car: puss
172wHP 240sx 5speed is a hell of a lot of fun to drive.on some streets i can chirp 3rd :ylsuper
sheadee240
Hotshot everything or everything nissmo?
What else other than headers does hotshot make?
technoman
Car: puss
__________________
Nissmo uses hotshot if you order headers from nissmo you will get a hotshot header. same for the intake.
TrunkMonkey
technoman wrote:same for the intake.
nissan motorsports doesn't sell an intake.
