Arias makes pistons with a 10.7cc dome for the SOHC only. I don't believe anyone makes DOHC domed pistons, they'd have to be custom order, but there's no reason when you can just run SOHC flat-tops.
personally, I like the SOHC better. You can put DOHC valves in (they're slightly larger) and there's tons more meat to hog the ports out with. Not to mention more cams are available. but that's just me
but I also wouldn't ever use that head on a 2.4L either. The valves are just too small for an engine that size.
The reason the KA doesn't make as much power as a B16 is because of its size. They almost flow about the same amount of air when ported, but one is 800cc's larger than the other. The KA has more rotating mass, and it's only half counter-weighted. The KA, however, knocks the socks off of the B16 in the mid-range and low-end torque department, which is why it's such a formidable motor for forced induction. It just can't BREATH in higher rpms, not to mention it really really hates to rev.
