All motor e-manage?
SSS
Anyone here running a Greddy e-manage on an all motor KA? Can anyone share experiences/problems/opinions/criticisms on this unit, cos i am considering it on my all motor FWD KA24E. It's a daily driver, so i only want a piggyback unit.
C-Kwik
There is no S13 KA application. There is someone on the E-Manage list trying to use it on an S13 KA, but I haven't heard if it was successful or not. I'm fairly certain it can work, but you'ld probably have to use a setting from a Japanese spec application and if the MAF voltage curve and fuel injector sizes are different, the tuning scale will not be accurate. Though, with some trial and error, you can probably account for it.
95_240sx
Car: My baby (car)
I thing the E-manage, being a piggy back would be universal, your just going to have to do some custom wiring.
Rick
nismofan14
Greddy is using it in there long awaited turbo kit for the 95-98 240. I pretty sure it would be possible in an s13, a friend of mine has one on his s14 and it is pretty sweet. I like the option of being able to overide the MAFS when it is to the max. All you would have to do is find out what wires are used and refer to an ecu pinout when installing it.
themadscientist
it has KA applicationshttp://www.mohdparts.com/emana...9.JPG
I am Technoman
Car: ???
. The greddy e manage has dip switches in it that need to be set for what ever motor. Like a garage door opener
themadscientist
So the E-manage will open garage doors too? :jump
I am Technoman
Car: ???
themadscientist wrote:So the E-manage will open garage doors too? :jump
Yes! and if you press the PTT mic on a UHF 2 way radio on and LTR network. Garage doors will open all over town! for miles!
C-Kwik
themadscientist wrote:it has KA applicationshttp://www.mohdparts.com/emana...9.JPG
Yes, but only for the S14. For the S13, you can likely use an application from one of the NA 4-cyl motors in Japan, but the map scaling may be off. In other words changing the tuning map by 5% may not give you a 5% change in fuel flow. There was a guy on the e-Manage yahoogroup rying it on an S13. I haven't heard if he got it running yet or not.
