If its a new meter than its probably not that, I was figuring it was an old meter.
Injector #1, 2, and 8 can be changed without pulling the plenum. Looking at the engine from the front, the front right cylinder is #1 and the front left is #2. All cylinders after #2 are 4, 6, 8 and after #1 are 3, 5, 7. I've been really lucky as I have had to only replace #2 and #8, though I think I have another going bad under the plenum.
If you pull the plenum you are going to want to replace the injector and knock sensor sub-harness because it may be part of the problem. In fact some of the issues with the knock sensors not working is really just a bad harness.
