All i need is a MAF!
nab911
Car: 93 Nissan 240SX SE
I need a new maf to get my car running right. Can i use any infiniti maf because i found one cheap and its a three wire... which is what i think the ca uses. I need a maf that can hold up to 300hp but i want it to be cheap.
pulsar gtr
Car: NISSAN VEHICLES
If you want to use a maf that is bigger than your stock one, you need to program your ecu to work with it.
The infiniti J30 maf is the same as the z32 maf.
PULSAR GTRRafi
sdtouge
Car: 1990 240sx coupe
ka24e maf. look on ebay or i tihnk 240sxmotoring.com has one under thier used parts section.
rico05
Car: 1992 RMS13 w/ CA18DET
I have a stock KA24E that ran my car fine (keep it as a backup) that I could let you have fo cheap to get ya runnin man.
[email protected]
nab911
Well the maf i have works, but i think my problem with it stumbling after 4 lbs is because its pushing power beyond what the ca maf can handle. I have a very big t3/t04e turbo and 2 1/2" IC piping with bigger injectors so i think the car is just hitting boost cut. So whats the cheapest maf i can get to see if that is the problem?
rico05
Prob Z32. About $150 usually. Is your ECU chipped? Get rid of boost cut that way.
nab911
i have a socket and chips to burn for the ecu but havent gotten that part down yet. I just need a quick fix to see if that is the problem. Will a q45 maf work? The plug looks different but the one im getting has the plug and about 6" of wire.
Loofee95SE
Car: u gota sister??
Ok i just swap A ka24e maf on a CA because the CA maf crap out. It crank right up. But!! I want to know what is the differrent betwen the both of them..and what is the extra wire from the ca harness for. thanks C
nab911
Rico, i have a guy here who said he might have one but if he doesnt and you dont mind parting with that maf, i may take u up on it.
