fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Wed Oct 09, 2002 5:18 pm
I'm actually not sure if it's feasable to put the s14 SR20 into the S13 chassis... I would guess yes- maybe someone else can confirm that for me? I might be wrong.
As far as the engines though, here's the deal from what Ive read so far: the s14 SR20 has a few differences from the s13 that you should pay attention to rather than the HP difference. It's got a different turbo (as you mentioned), a high port flow design (while many pefer the low port design which is in the earlier s13 engines), and VVT (variable valve timing).
Now, I've read this many, many times through this forum (hint hint-- everyone is gonna tell you to SEARCH... Im just gonna hint at it like this... *hint*), that the S14 will be better for you if you dont plan on upgrading or building the engine much farther than it already is. The VVT will have to be taken off if you decide to do any major work, and that (among other things Im sure) is a major source of it's added horsepower. If you're planning on building your engine, then maybe you should just stick with the s13. Word is (on the forums..... *hint*) it has more potential due to its port design, etc... and you wouldnt be wasting money for the VVT youd be ripping off anyways..
Hope I helped!
