Sure there is. It's called RPM. A stock KA produces about 165 lb-ft of torque at 4500 RPM(Rounded off). If we assumed it was in a car that had a 1st gear overall ratio of 8:1, then it would produce 1320 lb-ft of torque at 562 Wheel RPM. Now take a motor that peaks at 7000 RPM, and divide 562 into it. This gives you a gear ratio of about 12.5:1. and to make 1320 lb-ft of torque at this gear requires 106 lb-ft of torque. Now imagine, VTEC integras put out more than this across a relatively broad power band all the way up to 8000 RPM. No wonder they make so much HP. Any high revving motor has similar effects, depending on the amount of torque it can put out.Daunttless wrote:I don't think negatively of the SR20, I try to point out that each has its strengths and weaknesses. : ) They really are both great motors, and it just depends on how you want to do things. Paul is really the only SR Hater here. : )
C-Kwik wrote:
S2000...
I resemblem that remark. But I have lately gain a rather large interest in these wonderful REAR WHEEL DRIVE 240sx/s13.Now I just need to find a 95' s14/240sx coupe for me to play with, well after I finish my girlfriends paintball marker.sheadee240 wrote:
VTEC is great, but I'd rather have rear wheel drive
