Blackmobile »
https://forums.nicoclub.com/blackmobile-u106210.html
Sat Oct 31, 2009 9:56 am
this depends if you're getting G35 rims with stock rubber. the potenzas are directionsl tires with dedicated sides, each tire is marked which side should face outside, which means you can't rotate them at all. just make sure you get an alignment to make sure they all wear out roughly the same amount, and if you start to get a little more wear on some parts of the tires then get them readjusted to compensate. for me, i'm just driving with mine until they're unusable, I don't expect that they'll have the same life expectancy as tires which are rotated, but that's what you get with the stock rubbers. im going to make sure that my next set is rotatable though.
