All 3 cylinders on driver side not firing
Twin_Turbo_300zx
Car: Nissan 300zx Twin Turbo
I recently replaced all of my injectors, my head gasket, timing belt, water pump, intake mani gasket and some other gaskets and misc parts.
The car ran alright for a few weeks then had a weird loss of power there was a small fuel leak I fixed the leak and nothing changed.
I recently discovered the ecu was throwing a knock sensor code, I had connected the Knock sensor to the wrong plug so I swapped the plugs. The car ran slightly better but not right. There were no codes after that.
I decided to check and see if all of the cylinders were firing and discovered all 3 on the drivers side were not firing. I replaced the ptu with no change. I am going to ohm the injectors, check for power to the injector and check for spark on all the coils but with all 3 not firing I see there being a problem elsewhere.
Any help or suggestions on what to try would be great.
Thanks in advance!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
with all 3 ont he same side being an issue it could be a woring issue, but first step si determine if it's a spark or fuel issue
Twin_Turbo_300zx
:wtf2: Well I quickly checked to see if there was no spark or no fuel and both looked fine. I tested voltage to each injector and each coil and I checked the injectors them selves. I am thinking maybe somehow the valves got messed up or the timing belt slipped a gear. That or somehow all 3 of those cylinders rings are having issues at the same time or all 3 coil packs went out. I am going to pull the plugs and do a compression test asap. I will swap the coil packs to the other side or test them while they are out.
If anyone has suggestions please let me know.
evildky
06 Nissan 350Z GT
but you haven't verified spark yet? why would you jump to physical engine issue without ruling out spark first? spark is a much mroe likely issue, unless you are 100k on the timing belt or someone who doesn't knwo how to instal the tensioner put the belt on
Twin_Turbo_300zx
I wasn't ruling anything out yet, I mentioned I planed to test the coils. There is power going to the coils and seeing as all three cylinders on one side are not firing, I was thinking it could be a valve issue. I am no pro mechanic I am just trying to trouble shoot the problem as best I can. I triple checked everything with the timing belt and installed a new tensioner but mistakes do happen and so do weird mechanical issues. I have installed timing belts no problem before and as said I triple checked my work.
I will check everything as far as ignition goes asap I just didn't have any tools yesterday when I checked voltage and ohms to the ignition and fuel system.
Out of curiosity what does "100k on the timing belt" mean? Do you mean 100k miles? I mentioned in the first post I installed a new one while doing the other work.
I appreciate your input thank you.
