aligntment dowels in block + arp studs, both necessary?
jt15833
Car: 95' 240SX
I understand the need for the 2 alignment dowels in the block (intake side, one up by water pump one @ back of head) for use with stock head bolts.
Are they necessary for use with ARP head studs? Anyone had luck without them?
bentvalves
Car: 89 Silvia K's
yea for sure if the ARP hardware doesnt interfere with it, which theoretically it couldnt, then yea you would want to use them.
Chris859
I definately recommend using the alignment dowels with the arp studs - at a bare minimum they help keep everything square and together while tightening the head studs. I can also personaly say they do not interfere at all...
