Alignment
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Cheatermouse
Car: 2007 Nissan Versa Sedan
I'm planning to replace my stock spring and shocks with Tokico "blue" and Tanabe nf210. I understand that I need to have an alignment when I lower my car, but is there something else I need to know about alignment? what is this camber thing? Do I need to buy anything else for alignment?
JayyV09
Car: '09 Nissan Versa 1.8L SL (Super Black Hatchback)
i have the same questions
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
You should have the alignment checked after you do springs/struts.
As for camber, it refers to the angle from vertical that your tires sit. Generally they should sit slightly inward, but after lowering springs they usually sit more inward (negative on the diagram below). Really negatve camber tends to wear the inside of the tires more than the outside.
I just picked up a set of camber bolts and rear shims from Micro Image a couple weeks ago and will do my alignment/fix the camber with those items I bought.
Cheatermouse
I'm guessing I also need to buy those??
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
It depends if you need them. My guess is yes, buy them. But others have not adjusted their camber after springs or coilovers and are OK with it. I am just being a nervous nancy and picked up a set just in case.
Cheatermouse
How would I know if I need it or not?
JayyV09
according to ur picture PL, both tires should be at Negative when its lowered correct?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
yes, both negative slightly.
go to an alignment shop and have it measured Cheatermouse.
Return to “Versa Technical Discussions”
