C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Dec 24, 2003 5:52 am
just to clarify, if your alignment is ok, then it will not help with your fuel economy. If there is a problem, then yes.
I'd do a tune-up, including new spark plugs, air filter and fuel filter. Check the wear on your distibutor cap and rotor. Replace this if necessary. You can also try checking the engine ground straps to make sure the connections are good and clean. I've actually heard of some KA owners getting a significant improvement in gas mileage by doing this. Maybe run some injector/intake cleaner through the fuel system as well.
