Alignment
kingorcus
Hey guys just did alignemtn on my 02 pathyhere are the numbers LEFT RIGHTCAMBER -0.47 -0.38CASTER 3.36 3.46TOE 0.10 0.09INC ANGLE 18.89 17.06SAI 19.36 17.43
TOTL FRONT TOE 0.19
all these numbers look within specs except the INC angle and SAIand these are not adjustable they change when changing camber....
any idea guys??
the car drives ok, although I have a feeling that's its pulling to the right a bit...
Thanks
voolover
Car: 2002 pathfinder-90 Axxess
The s/m says you have a pulling condition when the vehicle moves over a complete lane within 7 seconds on a straight and level road without help from you. Now, imagine you are cruisin along and just happen to be asleep or talkin on the phone ... which way (rt or lft) would you want a slight pull to be?
kingorcus
so if my CASTER CAMBER and TOE are within specs, why the SAI and INCLINE angle are out ??
should the car by default pull a little to the left , because of most of the roads are curved to the right so it compensates..
also the left wheel camber should be slightly positive than the right wheel to make up for that.. correct???
voolover wrote:The s/m says you have a pulling condition when the vehicle moves over a complete lane within 7 seconds on a straight and level road without help from you. Now, imagine you are cruisin along and just happen to be asleep or talkin on the phone ... which way (rt or lft) would you want a slight pull to be?
