logoung wrote:Will the alignment go into spec without camber kits and new tie rods? I was told that the alignment won't be able to be done correctly without the install of camber kits and new equipment to allow adjustment of toe also....
Well, to save yourself some money in the long run from having to keep coming back and getting alignments like I did, get those if you can now. Tie rod is not "as necessary" but couldn't hurt. By not getting the camber kit, you are limited to whatever the factory settings can do. Camber Bolts are like $20-30, so just get it. The Rear upper control arm for camber is your call, as well as the front upper camber plate. Stay away from ebay arms - they aren't that great - I have em, they're meeehhhh - waiting on my teins right now.
With the pro kit you are really only lowering about 1", so you don't need anything major. When I did sport lines, I needed camber kits (stupid bolts that do 1 degree) + rear upper control arms to get the rears back into spec. I also had to get tension rods to put the caster back in its place in the front - that could have been due to a variety of reasons, though.
If you are really picky, then get the rear toe arms too to balance everything out & the tie rods w/ adjustable ends so that the tie rods sit correctly. But again, 1" isn't much of a drastic drop, this is more for people running coilovers or 2"+ drops, etc.
