Camber and caster are not adjustable on this car, only toe. They definitely used the wrong car though. Sometimes they do not have the correct car available in their alignment machine so their alignment machine tech support will tell them what similar/related car has equivelant specs. This may be the case.
You can check the Min/max on you sheet against these from the Factory Service Manual.
AWD
Here are the RWD specs in case someone finds this thread and needs them.
RWD
