Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Nov 04, 2003 6:45 pm
please dont act like your talking to someone who doesnt know what im talking about. I was respectfull.
myself, dori-dori, smithsr, ITA240sx, c-kwick and dennis(q45 tech) had a long draw out discussion about the dynamics of camber and toe and caster a while ago, suffice to say, anything over 2 degrees is far overkill for any street car with street tires.
sure, for track events, with competition tires, you may want to run more camber based on your roll center and observed contact patch roll(makring the sides of tires durning the event/testing)
camber does hurt tires, because when you drive straight, if you have the tire leaning in(negative) a proportinate ammount of weight is shifter to the inside edge of the tire, versus toe angle, where if you have too much negative toe, the inner edge of a tire is quite literally being scrubbed allong the ground if its bad enough..
and your camber settings are correct for drifting, but you probably know that. I dont think many people want a drift setup when driving on the street. you should seriously try less positive toe, you'd be suprised how well the car would respond to steering inputs with less toe in.
anyways, suffice to say, I really do appreciate the input, its nice to know what you run for a drift car.-chet
