Alignment specs
Taunto
Hey guys I'm looking for alignment specs for a 97 240SX RWD, (front whel steer only) if you guys know any sites or anywhere I can get this information that would be very much appreciated
working4aS13
Car: Base 95 240SX
The factory service manual has this information? Its on page FA - 15.
http://carfiche.com/manuals020/cars
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The S14 OEM alignment specs are: Front: camber: -1 degree 30' to 0 degrees caster: 6 degrees to 7 degrees 30' toe-in: 1.5 mm to 3.5 mm (0.059 " to 0.138 ")
Rear: camber: -1 degree 40' to -0 degrees 40' toe-in: 0 mm to 5.0 mm (0 " to 0.197 ")
Taunto
Thanks a lot guys!
