IlsG35 wrote:I DID THE ALIGNMENT TODAY I WORK AT A SHOP BUT BEFOR I DID IT THE WHEEL WAS A LIL OFF CENTER SO I PUT IT ON THE ALIGNMENT MACHINE AND AND THEN WHEN I WAS DRIVING HOME I NOTICED THAT IT WAS OFF MORE THEN BEFOR. THE ALIGNMENT WAS DONE TODAY ILL DO IT AGAIN TOMORROW BUT THE ASE TECH SAID THAT SINCE I HAVE WIDER TIRES THEN STOCK IT THROWS OFF THE MACHINE.
Wider tires do not "throw off" the machine. He either doesn't know what he is talking about, or you misunderstood what he said. Doing alignments on your car should be done exactly the same as they were before, and you should have no issues whatsoever. You should align the car to the same specs as stock, unless you are looking to change handling characteristics.
I also don't know what you mean by "off center" when reffering to the wheel.
Also, why are you typing in all caps?
