Alignment Shops Need Recommendation !!
G35
Hey Everyone !! I have two questions maybe someone in here can help answer them. Anyone know of a good alignment shop in Los Angeles,Ca. that is cheap, reliable and do a good job??
By any chance does anyone know if the alignment is cover in the car warranty?
Thanks in advance.
ArEs23x
Car: 2006 G35X
I really cant give you a straight answer on that since I havent needed any of that as of yet.. But I am sure someone will pop in real soon to answer your question...
Welcome aboard my friend.. Glad to have you here
telcoman
G35 wrote:Hey Everyone !! I have two questions maybe someone in here can help answer them. Anyone know of a good alignment shop in Los Angeles,Ca. that is cheap, reliable and do a good job??
Thanks in advance.
I have found that you usually get what you pay for. You can check prices at Goodyear, Sears etc. and compare those with what your local Infiniti dealer is charging. If there is only a small difference in price, I would go with the dealer.
I don't believe alignment is covered in the warranty but I could be wrong? Wheels can go out of alignment by hitting pot holes etc.
Telcoman
abdoman
Car: 2006 G35
If you are going to a dealer for an alignment, ask if they have an alignment machine. A lot of dealers send it to a local alignment shop to be aligned and they charge you more.
xilef
You may want to check out Big O Tires. They have a really good alignment equipment but are a bit pricey. Also, make sure you actually need an alignment. Do you have an irregular tread wear? Alignment would almost never fix the problem for me. They can only do so much with alignment. Oftentimes, it is something else that is causing the misalignment and needs to be fixed.
pae9132
Car: Modified 03 V35
I was just reffered to a shop here in the city of Orange if you are willing to drive to orange county. The guy does all of the alignment work for the people who work on my car at Project Import. I haven't been to this guy yet but he gave me some good information on the phone. Here's the info to call...Accurate Alignment#714-538-1916971 N Batavia, Unit AOrange, CA 92867
He might be able to atleast answer some questions for you like he did for me. Goodluck
