Over the past year I have managed to collect up a full S13 rear suspension arm setup - RUA, RLCA, RToe & RTraction. All eBay ultra-cheap ones, mostly sniped for silly low prices. For example, I got Rear Toe Arms plus Rear Traction Arms for $45 shipped from an auction with very few bids.
I'm considering replacing the Heim Joints with better ones before installing them. Heim joints seem to be the weak point on cheap Chinese arms. I found the "High Quality" RUA Heim joint for sale on AliBaba for $1 each (
http://gzhearing.en.alibaba.com/product ... aring.html). I have found an exact size replacement here:
http://www.midwestcontrol.com/part.php?id=3002 for $8 each.
Question 1: $1 each vs $8 each - hmmmm, is this really enough of an upgrade? I'm thinking yes.
Question 2: The original aftermarket RUA joint has a brass race (the others are steel) so should I use brass, steel or teflon-coated for the replacements? Teflon is recommended by many online.
A little background: S13 1993 Convertible 110k miles, TEIN FLEX Coilovers, new OEM FLCAs with new ball joints & Whiteline bushings, new front swaybar links, adjustable front Tension Rods with Heim joint no bushings. Rear is 100% stock except for the coilovers. Lowered a medium amount, still has about 3/4 inch space between tire and fenders. I do not race the car, just spirited road driving - no drifting.
I had a steering wheel / whole car wobble the other day when I really hammered on it and shifted violently. The wobble went away but I thought for a second I was losing a wheel from loose lugnuts. All wheels were plenty tight, so now is the time to do something about the rear suspension - a full inspection reveals absolutely nothing visibly wrong - all bushings 100%, nothing visibly bent, nothing moves when I try to shake it.
I have always had a slightly visible issue with my rear passenger side wheel alignment. I had an alignment done but the shop was not very interested in anything but taking my money. They fixed the front toe (I had replaced tie rod ends) but literally did nothing to the rear at all despite me telling them I had a visible issue and wanted the readings to be centered in the green range.
Here are the numbers from the alignment sheet:
Measurement / Before / After
FL caster / 6.2 / 6.2
FR caster / 7.0 / 7.0
FL camber / -0.3 / -0.4
FR camber / +0.4 / +0.4
FL toe / -0.80 / 0.05
FR toe / -0.05 / 0.05
RL camber / -1.9 / -1.9
RR camber / -2.6 / -2.6
RL toe / 0.70 / 0.70
RR toe / -0.05 / -0.05
I have found an alignment shop that is willing to adjust the arms (mostly because they are brand-new!) and set them where I want them not just to spec.
I have the following target settings in mind:
F camber -2.0 degrees
F toe 0.0 mm
R camber -1.75 to -2.0 degrees
R toe 0.5 mm in
Thanks in advance for your thoughts or advice here!
