factory settings work fine. but if you want to have some fun with it, i have mine set to 0 toe in the front. it turns in quicker and the rear end comes out easier on sweepers. since you don't have camber plates up front you won't be able to do anything to the camber there, don't worry, it's probably about right for what you want to do anyway (probably about 1.8 deg). i would run a little less in the rear, 1.5-1.3 deg. you can make some minor adjustments in balance by changine the air pressure front to rear also.
a basic alignment shop probably won't adjust your RUCAs or they will charge extra, and they won't really know what they are doing. try to find a race alignment shop like this one in austin,
http://www.soulspeed.com/. they will probably give you better advice than anyone on this board.
