bullittandy wrote:I just got my other car (1994 Caprice wagon) aligned by local Goodyear Gemini shop and the "after" measurements have "modified specification" next to the car model. It appears that the tolerances are "looser" ie camber was (before) -0.8 on driver side and "red" and after is -0.9 and in "green."
Did I get cheated? What does that term mean?
If it says "modified specifications" that means, the guy doing the alignment didn't want to adjust something so he manually adjusted the specs.... how can I explain this.... let's say left camber spec is. -0.7* with a tolerance of +/- .5* so and where from -0.2* thru -1.2* is still in spec.... now let's say your car rolls on the rack with a -1.8* camber which is out of spec or in the red. Without touching 1 wrench I can go on the alignment computer, punch a few buttons and make that -1.8* in the green by either making a new camber spec, or widening the tolerance... you get it?
In other words, I'm guessing the mechanic saw that from right to left, the actualy alignment numbers were even from left to right, but numbers were in the red, so he altered the specs for it to be green, probabaly only adjusted toe, got paid 10% of the actual alignment cost, and called it a day...
If any alignment sheet read out has a "modified specification" typed on it, the guy plugged in new numbers, or in other words, you got cheated.... ill admit, I've don't it a few tims, but only for cars that do not have camber or caster or toe adjustments... anything else that can be adjusted either stock of aftermarket tools, ill adjust it....
And its not hard at all to adjust camber/caster on a b-body impala/caprice, its only shims.. what's sad too is I work at a goodyear gemini here in hawaii.... you should call goodyears hotline....
