Alignment question - reason for concern?
Chaz98Q45t
Car: Kids, motorcycles, softball
hey guys - I have an alignment question. Just got new rims (2003 350z rims) and tires (Falken 512's) which I like very much. So I got the car aligned and the rear left was unable to be aligned to within specs. The car is a 2000 Q45t with 54,000 miles - numbers as follows:camber before: -1.8camber actual: -2.2 which is out of the specified rangecamber specified range: -1.3 thru -0.3toe before: 0.29toe actual: 0.16toe specified range: 0.00 thru 0.23
All of the other alignment #'s were within spec -Alignment was done at Tire Kingdom in Palm Harbor, FL. a chain of dealerships in FLA.
Please let me know if any additional info is needed.I asked the guy at Tire KIngdom how to fix or if it was OK to drive - he mumbled something. So I just told him that I would research myself - so I'm starting here, as everyone good NICO owner should.Thanks in advance -
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check around for rear upper adjustable control arms.
Can't recall who has used them on an FY33.
