Alignment problems, need help badly
psyclone69
I lowered my 95 240 about a month ago, rode fine, just got an alignment, and they had a problem with my front passenger side, camber is at -1.8', when the drivers is at -1.4' couldn't get pass. side any lower, but the main problem is the caster is 4.4' on the pass side, and 6.7 on the drivers side, with a cross caster of 2.3'.
Anyone know how to fix this problem? we looked for any spots that looked wrong underneath, and nothing.
Any help is greatly appreciated.Thank you.
psyclone69
anyone?
drjohn
You may have to find a camber kit to get the camber in. This goes neg. when the car is lowered. the caster may require loosening all the tension rod mounting bolts on the frame bracket and the lower control arm and pulling the 4.4 side forward and the 6.7 side backward and try to get them even. Caster won,t cause tire wear but will cause a pull. You can loosen or enlarge the top strut bolt hole in the steering knuckle to get more pos. camber.
