alignment problems and brake light is on. Any thoughts on why?
Including HI and CA
y11ngdanjr
Car: 95 240sx
I gotta 98 240sx
So I lowered my car 2 days ago and put sportmax 962s with 10mm spacers on to clear my big brakes and drove for like 50 miles and then put back my stock rims. I changed the rims back to my stock se rims because the ride was really bumpy. I think it was due to the spacer and now the stock rims are pulling my car to the left when I drive. Do you think my tires are unbalanced or my alignment needs to be adjusted? Do you think the rims with the spacer could have made my my alignment bad?
My emergency brake light is also on for some reason and I don't know why. I'm going to check my brake fluid 2moro.
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
It's recommended u get an alignment when u drop ur car.
y11ngdanjr
Car: 95 240sx
yea ur right. I'mm going to go as soon as I get my rims. I found out the prob tho. It's stupid. One of my tires was almost out of air. The brake light problem was just lack of brake fluid so I put some in and wala!
Return to “California Region”
