Alignment Problem...
fB2k
I had my alignment done at STS when I bought new tires (Toyo Proxes TPT). My question is that after alignment, should the car still tilt to the right? It's much better than before but still does it slightly. I talked to the guy who worked on my car and he said there are no problems. Any ideas?:help
Exar-Kun
Car: 2005 350Z
what do you mean by "tilt to the right"? like the car itself or the steering wheel, or what?-chet
fB2k
sorry to be vague, but the steering wheel
Exar-Kun
Car: 2005 350Z
does the car pull, or is the steering wheel just tiled? if the steering wheel is tilted, get the alignment redone, if it pulls, chek your alignment readings, check for a camber or caster split.-chet
