alignment problem installing transmission
240pop
Car: 240SX S14
I just got done replacing the clutch...now I can't get the transmission back in.Is there some special technique? I've tried raising the whole thing at once, but the bell housing hits before the shaft is aligned. If I keep the back of the transmission too low, it can't make it either.
Do I need to twist the transmission to one side or another first?I've never had this much trouble aligning any transmission before, and I've done them without a jack by myself.
I feel like I should have just paid someone to do it.
I'd appreciate any tips.
Thanks
carkook
Yeah, its a pain compared to most cars. We had to twist it alot, and even drop the engine away from the firewall a few inches.
this explains it alot better took two seconds to find.
zerothread?id=318898
240pop
Car: 240SX S14
Thanks Kook....I'll try that tomorrow.
I thought about jacking up the front of the engine a bit, and leave the engine mounts in place, but I think it'll be a combination of things.
240pop
Car: 240SX S14
I got the transmission back in finally, but if you can believe it, the POS clutch is slipping again.....any ideas?
tre4s13
Car: 89 Zenki s13 with a 94.5 DE swap.
Quickest/best way to put a transmission on is pushing it in with an up and down motion @ the same time, twisting may help.
240pop
Car: 240SX S14
Thanks for the tips.
I adjusted the pushrod from the clutch pedal and that took care of the slipage.
