300zxstanced wrote:I had something similar to those, they worked fine but the welds started to rust after about 6 months (you get what you pay for), I didnt want to take a chance so i replaced them with these. They dont have welds, and they have been in for 1-1/2 years and they look and work fine. I know everyone tries to save some $$ including myself, but sometimes its better to just buy the proper thing the first time around. While your doing the suspension work you may want to look at your control arm bushings and your tie rod end to save you time.
http://www.ebay.com/itm/Nissan-300ZX-Z3 ... 065wt_1017
These will help your camber, will do nothing for your caster. For caster you will need tension rods. Looking at your alignment sheet, if your tension rods are stock, it looks like your bushings are shot. You can get poly inserts, they work fine, but if you get adjustable ones you can really fine tune them to get the angle you want.
