12Ounce »
https://forums.nicoclub.com/12ounce-u52716.html
Sat Dec 30, 2006 3:52 am
If you've replaced suspension/steering components you can expect alignment issues.
You may want to get the alignment "in the ball park" to save excessive tire wear before going to the professionals .... that is, unless the professional shop is very close by. It's easily done.
Process: Bring the car to a slow stop, on level ground, with the steering wheel straight ahead. Then eye-sight against the side of the front wheels (from front to back ... at half wheel height) toward the rear wheels ... compare both sides. If you now adjust the outer tie-rods so that the front wheels are parallel with the rear ... you will be in pretty fair shape.
"Parallel" is usually included in the acceptable range of most alignment specifications. However, if you know the actual specs for you car (and can do the "trig") you can go for the actual specified toe-in adjustment by having someone hold a rule against the rear wheels as you gun-sight them from the front. It ain't rocket science ... but it does involve a bit of math!
Repeat the "Process" (above) until the car steers straight ahead and the front wheels are near parallel with the rear ... or within "specs".
This should get you in pretty good shape until you can make it to a shop. (Though I never go to one ... I've been doing this self-slignment for some years! And I get excellent , and even, tire wear.).
Modified by 12Ounce at 6:12 AM 12/30/2006
