zul8tr »
https://forums.nicoclub.com/zul8tr-u26979.html
Sat Feb 04, 2017 3:17 am
Have you resolved your alignment/handling issue?
I have always aligned toe in with string very accurate and as you note most shops do terrible alignment, Old School since race days but it works, I do it on all my cars, tires run true and wear well.
Have you checked your car for equal ride height L to R ?
Was the alignment done with tires at equal inflation L to R ?
Are the rims true with no lateral runout, can't get reliable toe in if not true?
Have the front ball joints been checked for excess play?
What are the present alignment numbers, caster, camber and toe in?
Some cars need a camber kit as they age they sag and that greatly affects alignment especially if camber way different on each side.
Recently put tires on the 98 I30 with 150k and set toe in with the string, car also has a front camber adjustment kit because 30k ago the camber was ot of spec each side each side and not camber not OEM adjustable. Kit easy to install and adjust if you know front end geometry basics.
If a DIY'er PM me and provide an Email address and I will detail the align process I do, very simple and will also give basic ways to check front end.
$2300 wow !
