95_SX_SE »
https://forums.nicoclub.com/95-sx-se-u6649.html
Fri Mar 12, 2004 7:57 pm
Q45tech, I don't think it's a camber problem as prokit springs only lower it about an inch, and the tires are only worn on the very inner edge (up to the first tread groove), otherwise they still have lots of tread. Problem is, the worn part is nearly down to the wear marker already.
NISTECH,I will try that, but what if the tie rods are very worn or other parts are very worn? Is there anything else I need to look at that could contribute to the problem?
